It is currently Thu Jul 17, 2025 11:21 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2
PostPosted: Wed Oct 10, 2007 8:30 am
Jim, I thought about the bridge a great deal before going ahead with the shared pin method. I've restrung enough 12's to be annoyed with the 12 pin set up. Every thing seems too cramped , and your strings often nudge other pins. To replace a string , you sometimes have to remove another pin , and that's if you CAN remove the pin . I also wanted to get away from having 12 holes drilled in this important area.
I saw Dave white and Howard Klepper use this system, and after some of their advice ,was sold on the idea.
All of us have used the Stewmac oversize pins . There is enough room and the strings seat themselves nicely.
It also allowed me to reduce the size/weight/footprint of a normal 12 pin bridge. I could also get the string spacing where I wanted it and not be dictated by the width of the bridge pins
CRAIG LAWRENCE of AUSTRALIA
PostPosted: Wed Oct 10, 2007 9:23 am
Cheers Chris !
                  The liners are a Charles Fox idea. A two piece arrangement , whereby the ( Walnut ) kerfed part is glued on first. This part has a rebate to fit the ( Tas. Sassafrass) strip flush, which is glued on as a second operation . It makes the rims very stiff and a nice solid area to glue on the plates and hopefully contain most of their energy. The sides are .1 " thick for the same reason
PostPosted: Wed Oct 10, 2007 10:41 am
Sorry Allen ,I missed your question.
Yes ,I use locating pins for the top and the back. Just ensures them to be glued in the exact correct spot and takes that issue away when your rushing to get the glue-up done while the stuff is fresh.
Actually ,a fair bit of the inside detail is noticed through the soundport. I find people delight in peeping inside.
Thanks for your kind words mate
Regards Craig
PostPosted: Wed Oct 10, 2007 1:43 pm
Not bad for a second guitar
You know I love that guitar, almost as much as your first.
You can see the rest of that guitar here
PostPosted: Wed Oct 10, 2007 1:45 pm
Craig, you are a true craftsman.
PostPosted: Wed Oct 10, 2007 2:06 pm
I don't know how many times this has been said, but let me add it once more, just how elegant that guitar is.
I particularly like the "broken" purfling on the headstock/fretboard, and the way it is mirrored on the bridge. That is really something special.
Fantastic guitar Craig!
PostPosted: Wed Oct 10, 2007 2:09 pm
Kiwi mate, how come the inside of your second guitar looks better than the outside of my second guitar?
It just ain't fair.
PostPosted: Wed Oct 10, 2007 2:57 pm
That is really nice Craig
PostPosted: Wed Oct 10, 2007 5:06 pm
Wow, impressive piece of work!
Love the interior details.
PostPosted: Wed Oct 10, 2007 8:59 pm
Aww, is that sweet!
Max Bishop
Brighton, Michigan
Max Bishop
Brighton, Michigan
PostPosted: Wed Oct 10, 2007 9:36 pm
Dang.
PostPosted: Wed Oct 10, 2007 10:12 pm
Craig, this is a real showpiece!!! Congratulations!!!
long
PostPosted: Thu Oct 11, 2007 12:25 am
thats a real beauty,Craig!
PostPosted: Thu Oct 11, 2007 1:45 am
Many thanks Rod. I love my six string too . It's such a great guitar to play, but it has taken rather a back seat of late . I'm really getting into this 12 now . It sure rocks and is sounding better each time I have a session.
I'm pleased you like the broken ivory lines Steve. It's just something that came to me and became part of the overall design. cheers mate.
Appreciate it Paul and Jim.
Howard , it means a lot to me coming from you , and once again many thanks for giving me some of your time.
Max,Bob and Vachterm , you guys are too kind .
And Don ,,Thanks for another 'DANG '
I made the neck a bit wider at 1 15/16 " for a little more space between all those strings and am pleased I did. It's a total bolt on with carbon fibre rods and a two way rod
The body is 4 5/8 " at the tail
PostPosted: Thu Oct 11, 2007 9:44 am
Here's a shot of my little Paua Kiwi inlaid into the neck block , viewable through the soundport
PostPosted: Thu Oct 11, 2007 10:06 am
Dang #3 ! ! ! !
I'm just so floored with this one, and I was floored with your #1 as well. Everything about it exudes class and style. The laminated/purfled side braces, the Kiwi on the neckblock, the broken inlaid "purfling" on the neck, bridge, and headstock are too cool for words. Everything about this is expertly fitted and tastefully done. If I didn't know better, Id swear your last name was really Kinnaird or Klepper! I'm not sure how you can raise the bar any higher than you have, certainly I know of nobody's first and second instruments that I can put at this level. If it sounds as good and plays as good as it looks, it's a total winner.
PostPosted: Thu Oct 11, 2007 10:26 am
[QUOTE=Don Williams] Dang #3 ! ! ! !
I'm just so floored with this one, and I was floored with your #1 as well. Everything about it exudes class and style. The laminated/purfled side braces, the Kiwi on the neckblock, the broken inlaid "purfling" on the neck, bridge, and headstock are too cool for words. Everything about this is expertly fitted and tastefully done. If I didn't know better, Id swear your last name was really Kinnaird or Klepper! I'm not sure how you can raise the bar any higher than you have, certainly I know of nobody's first and second instruments that I can put at this level. If it sounds as good and plays as good as it looks, it's a total winner.[/QUOTE]
Don, Craig took his #1 to a local music store and was offered $5k for it by a nationally known musician who just happened to be there. So they sound as good as they look.
Sorry Kiwi I know you kinda told me that in confidence, but it just had to be revealed. I'd be telling everyone if it was me.
PostPosted: Thu Oct 11, 2007 10:29 am
Craig nice guitar shame you couldn't find any decent back wood
PostPosted: Fri Oct 12, 2007 1:30 am
Those are very kind words Don ,much appreciated.
Cheers Paul, If it hadn't been my first ,I may have grabbed it too !
I do build with the sound being top priority , but also enjoy the aesthetics
Yeah , the backwood is a bit rough Bob Fantastic wood to work and finish. No trouble bending the sides at   .1 " The amount of flame that popped out even surprised me !. I have another similar set fortunatley. Thanks Bob
PostPosted: Fri Oct 12, 2007 3:30 am
First name: Tracy
Last Name: Leveque
State: CO
Craig,
That is just fantastic workmanship, and a very beautiful guitar. I really like that rosette Looks very familiar. Congrats on a real beauty!
PostPosted: Fri Oct 12, 2007 9:55 am
An enormous thanks to L.M.I. for supplying me with such wonderful tonewood. I bought two sets of this Myrtle , with instructions "Please send me the best you have " , as at the time ,I intended this wood for my first build. Like all their tone wood , it was immaculatley prepared. Thanks guys for sorting out such beautiful wood
Also to Zhevlakov Dmitry (reputed to be the world's no.1 ) rosette maker and Tracy (Luthier supplies) for suppying it. I just couldn't resist using it, as it suited the guitar so well.
Thanks also to Rich. Lipp & Son ,(pianomakers )for the superb ivory used in the purfling
